Fit table?
loki3000
652
Does solidworks (i have 2008 currently, but will get 2012 soon) have a fit table (e.g. D20 h7 - the lower and upper limit value for it) that i could include in a drawing?
Preferrably via built-in swx method or do i have to write a macro?
I didn't mean like that.
I'd ideally want to have a table (general table, like BOM) near the head of the drawing that displays all fits and provides tolerances for them (as is per DIN standard).
Is there anything available that can summarize the surface finish (e.g. entire model 6.3, except for the marked areas that are 0.8 etc)?
When choosing the fit, choose "Fit with tolerances" and you'll see the numbers with the dimension.
If you really want the fit table on your drawings (which I agree is unnecessary, but I'll assume for this sake that you disagree) I would build the table once probably as a general table and then make a block out of it that you can insert on your drawings.
