bogiedreamer
- Apr 14, 2005
- 57
Hi all,
I finally got my model of helical spring compression to run.
Initially to keep the model simple, I define only E = 29,000,000 psi and PR = 0.3. The result seems a little high especially at the toward the end with larger compression (see attached graph).
Then I attempted to define both the Elastic and Plastic regions.
Elastic:
E = 29,000,000 PR = 0.3
Plastic:
Yield Stress Plastic Strain
1 29,000 0
2 35,600 0.000235
3 42,600 0.000474
4 63,400 0.001377
5 69,600 0.0018
With the plastic region included, the result is too low (the final force is only 40% of test data).
What am I doing wrong? Many thanks,
Elastic:
Plastic:
1 29,000 0
2 35,600 0.000235
3 42,600 0.000474
4 63,400 0.001377
5 69,600 0.0018
