Find the circle
hoangthe
17
I have a projection drawing from 3d, i need to find holes in circle in 2d drawing bane with macro but failed. Can anyone help me see where the error is?
Sub CATMain()
Dim drawingDocument1 As DrawingDocument
Set drawingDocument1 = CATIA.ActiveDocument
Dim SelectionsAll As Selection
Set Selection = drawingDocument1.Selection
MsgBox Selection.Count2
For i = 1 To Selection.Count2
Set RefView1 = Selection.Item(i).Value
Set Element = RefView1.GeometricElements
'Set Element = refView.GeometricElements.GetCurvature RefView
MsgBox TypeName(Element)
Select Case TypeName(Element)
Case "Axis2D":
MsgBox "Axis"
Case "Line2D":
MsgBox "line"
Case "Circle2D":
MsgBox "Circle"
End Select
Next
MsgBox "finish"
End Sub
Do you mean to count circles appearing in 2D sheet? If you want to find anything its not right code, firstly i recommend using method selectelement3 with triggering palette instead of preselection.
M
Little Cthulhu do you have any command to find them? tôi đang muốn tạo một macro như lệnh " hole dimension table" của catia
hoangthe.
You can find the circle by Isolating the link.
This is not a very pretty method, but here is an example of temporarily copying and pasting a view, Isolating it, and then deleting it once the necessary information is retrieved.
A new view is created near the origin, and the result is text for each diameter.
Code:
'vba
Option Explicit
Sub CATMain()
    Dim dDoc As DrawingDocument
    Set dDoc = CATIA.ActiveDocument
    Dim msg As String
    msg = "Select the view from which to extract the coordinates of the hole / ESC = Cancel"
    Dim selElement As SelectedElement
    Set selElement = select_element( _
        msg, _
        Array("DrawingView") _
    If selElement Is Nothing Then Exit Sub
    Dim view As DrawingView
    Set view = selElement.value
    Dim cloneView As DrawingView
    Set cloneView = get_clone_view(view)
    Dim circles As Collection
    Set circles = get_circles(cloneView)
    If circles Is Nothing Then
        remove_entity cloneView
        Exit Sub
    End If
    Dim groupRadius As Object
    Set groupRadius = group_by_radius(circles)
    Call dump_circle_info( _
        dDoc.sheets.ActiveSheet, _
        "coordinate by " & view.name, _
        groupRadius _
    MsgBox "Done"
End Sub
Private Function dump_circle_info( _
    ByVal sheet As DrawingSheet, _
    ByVal viewName As String, _
    ByVal dict As Object)
    Dim numericKeys As Variant
    numericKeys = quick_sort(get_numeric_keys(dict))
    Dim coordinateView As DrawingView
    Set coordinateView = create_view( _
        sheet, _
        viewName _
    Dim a
    Dim txt As DrawingText
    Dim idx As Long
    Dim coordinates As Collection
    Dim coord As Collection
    Dim infoLst As Collection
    For idx = 0 To UBound(numericKeys)
        Set infoLst = New Collection
        infoLst.Add " ** diameter:" & numericKeys(idx) & " **"
        infoLst.Add "- posX,posY -"
        Set coordinates = dict.Item(Trim(Str(numericKeys(idx))))
        For Each coord In coordinates
            infoLst.Add Join(col2ary(coord), ",")
        Next
        Set txt = coordinateView.texts.Add( _
            Join(col2ary(infoLst), vbCrLf), _
            idx * 100, _
            0 _
    Next
End Function
Private Function get_numeric_keys( _
    ByVal dict As Object) _
    As Variant
    Dim numericKeys() As Variant
    ReDim numericKeys(dict.count - 1)
    Dim ary As Variant
    ary = dict.keys
    Dim i As Long
    For i = 0 To dict.count - 1
      numericKeys(i) = CDbl(ary(i))
    Next
    get_numeric_keys = numericKeys
End Function
Private Function create_view( _
    Optional ByVal name As String = vbNullString) _
    As DrawingView
    If name = vbNullString Then
        name = "AutomaticNaming"
    End If
    Set create_view = sheet.views.Add(name)
End Function
Private Function group_by_radius( _
    ByVal circles As Collection, _
    Optional ByVal roundTolerance As Long = 3) _
    As Object 'dict
    Dim group As Object
    Set group = init_dict()
    Dim values As Collection
    Dim center(1) As Variant
    Dim dia As Double
    Dim key As String
    Dim c As Variant ' Circle2D
    For Each c In circles
        dia = Round(c.radius * 2, roundTolerance)
        Call c.GetCenter(center)
        key = Trim(Str(dia))
        If group.Exists(key) Then
            group.Item(key).Add ary2col(center)
        Else
            Set values = New Collection
            values.Add ary2col(center)
            group.Add key, values
        End If
    Next
    Set group_by_radius = group
End Function
Private Function col2ary( _
    ByVal col As Collection) _
    As Variant
    Dim ary() As Variant
    ReDim ary(col.count - 1)
    Dim i As Long
    For i = 1 To col.count
        ary(i - 1) = col.Item(i)
    Next
    col2ary = ary
End Function
Private Function ary2col( _
    ByVal ary As Variant) _
    As Collection
    Dim col As Collection
    Set col = New Collection
    Dim i As Long
    For i = 0 To UBound(ary)
        col.Add ary(i)
    Next
    Set ary2col = col
End Function
Private Sub remove_entity( _
    entity As AnyObject)
    Dim sel As Selection
    Set sel = CATIA.ActiveDocument.Selection
    CATIA.HSOSynchronized = False
    With sel
        .Clear
        .Add entity
        .Delete
    End With
    CATIA.HSOSynchronized = True
End Sub
Private Function get_circles( _
    ByVal view As DrawingView) _
    As Collection
    Set get_circles = Nothing
    Dim sheet As DrawingSheet
    Set sheet = get_parent_of_T(view, "DrawingSheet")
    With sel
        .Clear
        .Add view
        .Search "CATDrwSearch.2DCircle,sel"
    End With
    If sel.Count2 < 1 Then
        Exit Function
    End If
    Set circles = New Collection
    Dim i As Long
    For i = 1 To sel.Count2
        circles.Add sel.Item2(i).value
    Next
    sel.Clear
    Set get_circles = circles
End Function
Private Function get_clone_view( _
    As DrawingView
    With sel
        .Clear
        .Add view
        .Copy
        .Clear
        .Add sheet
        .Paste
    End With
    Dim tempView As DrawingView
    Set tempView = sel.Item2(1).value
    sel.Clear
    tempView.LockStatus = False
    tempView.Isolate
    Set get_clone_view = tempView
End Function
Private Function get_parent_of_T( _
    ByVal aoj As AnyObject, _
    ByVal t As String) _
    As AnyObject
    Dim aojName As String
    Dim parentName As String
    On Error Resume Next
        aojName = aoj.name
        parentName = aoj.Parent.name
    On Error GoTo 0
    If TypeName(aoj) = TypeName(aoj.Parent) And _
       aojName = parentName Then
        Set get_parent_of_T = Nothing
        Exit Function
    End If
    If TypeName(aoj) = t Then
        Set get_parent_of_T = aoj
    Else
        Set get_parent_of_T = get_parent_of_T(aoj.Parent, t)
    End If
End Function
Private Function init_dict( _
    Optional CompareMode As Long = vbBinaryCompare) _
    As Object
    Dim dict As Object
    Set dict = CreateObject("Scripting.Dictionary")
    dict.CompareMode = CompareMode
    Set init_dict = dict
End Function
Private Function quick_sort( _
    ByVal ary As Variant) As Variant
    If IsEmpty(ary) Then
        quick_sort = Empty
        Exit Function
    End If
    Dim stack As Object
    Set stack = init_dict()
    Dim leftIdx As Long
    Dim rightIdx As Long
    Dim pivot As Variant
    Dim tPivot(2) As Variant
    Dim temp As Variant
    Dim i As Long
    Dim j As Long
    stack.Add stack.count + 1, LBound(ary)
    stack.Add stack.count + 1, UBound(ary)
    Do While stack.count > 0
        leftIdx = stack(stack.count - 1)
        rightIdx = stack(stack.count)
        stack.Remove stack.count
        If leftIdx < rightIdx Then
            pivot = ary((leftIdx + rightIdx) / 2)
            i = leftIdx
            j = rightIdx
            Do While i <= j
                Do While ary(i) < pivot
                    i = i + 1
                Loop
                Do While ary(j) > pivot
                    j = j - 1
                Loop
                If i <= j Then
                    temp = ary(i)
                    ary(i) = ary(j)
                    ary(j) = temp
                    i = i + 1
                    j = j - 1
                End If
            Loop
            If rightIdx - i >= 0 Then
                If rightIdx - i <= 10 Then
                    insertion_sort ary, i, rightIdx
                Else
                    stack.Add stack.count + 1, i
                    stack.Add stack.count + 1, rightIdx
                End If
            End If
            If j - leftIdx >= 0 Then
                If j * leftIdx <= 10 Then
                    insertion_sort ary, leftIdx, j
                Else
                    stack.Add stack.count + 1, leftIdx
                    stack.Add stack.count + 1, j
                End If
            End If
        End If
    Loop
    quick_sort = ary
End Function
Private Function insertion_sort( _
    ary As Variant, _
    minIdx As Long, _
    maxIdx As Long)
    Dim i As Long, j As Long
    Dim temp As Variant
    j = 1
    For j = minIdx To maxIdx
        i = j - 1
        Do While i >= 0
            If ary(i + 1) < ary(i) Then
                temp = ary(i + 1)
                ary(i + 1) = ary(i)
                ary(i) = temp
            Else
                Exit Do
            End If
            i = i - 1
        Loop
    Next
    insertion_sort = ary
End Function
Private Function select_element( _
    ByVal msg As String, _
    ByVal filter As Variant _
    ) As SelectedElement
    Dim sel As Variant
    sel.Clear
    Select Case sel.SelectElement2(filter, msg, False)
        Case "Cancel", "Undo", "Redo"
            Exit Function
    End Select
    Set select_element = sel.Item(1)
    sel.Clear
End Function
kantoku
Thanks. I see this code select all arcs (not closed circles) how can only closed circles be selected?
hoangthe.
Rewrite the get_circles function next and add the is_close_circle function.
Code:
    As Collection
    With sel
        .Clear
        .Add view
    End With
        Exit Function
    End If
    Dim i As Long
    Dim crv As Circle2D
        Set crv = sel.Item2(i).value
        If is_close_circle(crv) Then
            circles.Add crv
        End If
    Next
    sel.Clear
End Function
Private Function is_close_circle( _
    ByVal crv As Circle2D, _
    Optional ByVal tolerance As Double = 0.001) _
    As Boolean
    Dim varCircle As Variant
    Set varCircle = crv
    Dim startAry(1) As Variant
    varCircle.StartPoint.GetCoordinates startAry
    Dim endAry(1) As Variant
    varCircle.EndPoint.GetCoordinates endAry
    Dim dist As Double
    dist = Sqr((endAry(0) - startAry(0)) ^ 2 + (endAry(1) - startAry(1)) ^ 2)
    is_close_circle = IIf(tolerance > dist, True, False)
End Function
kantoku.
thanks for your help, it's great
Sub CATMain()
Set SelectionsAll = drawingDocument1.Selection
For Each RefView1 In SelectionsAll
Dim Elements As GeometricElements
Set Elements = RefView1.GeometricElements
For Each Element In Elements
Case "Axis2D":
MsgBox "Axis"
Case "Line2D":
MsgBox "Line"
Case "Circle2D":
MsgBox "Circle"
End Select
Next Element
Next RefView1
MsgBox "Finish"
End Sub
