cliffy
- Jun 2, 2001
- 18
Hi all. I don't know if this is the right forum for this so sorry if it's not.
I am wondering if it is possible to filter gasoline or diesel or fuel oil, etc. vapors out of a stream of air coming from a shop vac.
As you may have guessed, the shopvac is not expolsion-proof/inherently safe but I would like to make it so on the cheap.
The flow will be around 50-100 cfm @ 30 psi max.
I'm assuming the media will involve activated charcoal or similar, but a couple hours of searching has not turned up anything promising.
Any thoughts?
thanks
Any thoughts?
thanks
