Tomfh
- Feb 27, 2005
- 3,592
A contractor has made 30mm saw cuts in a new 200mm thick suspended driveway slab which is supported on piers. The slab is on ground, however is piered to rock due to hillside construction. (The surrounding slab on grade driveways have a history of settlement and failure.)
The slab is reinforced top and bottom, and still works, however the cover to top steel is reduced, as is effective thickness.
The slab slope at around 5-10%.
Anyone have experience filling cuts like this? Epoxy? Grout?
