WITT55
- Aug 24, 2000
- 7
I am doing FEA for a complicated connection in a steel framed building. I am in search of a code or reference that would provide me with an allowable stress or strength of the steel. It seems that the AISC manual does not apply as I do not have simple bending, tension or compression forces. I want to have an appropreiate factor of safety at the same time not being over comservative, as it has already been designed by my client and is used numerous times. Have you done a FEA of steel before, what did you uses as an allowable stress and what was your basis? Any help or direction would be greatly appreciated.
Thank You,
Thank You,
