Export/Save as an assembly to jpeg
caruana
Automotive
Jun 23, 2003
37
Hello
Is it possible to export or save as an assembly and create an image file (jpg) of each member of the assembly?
Thanks.
What version of software are you using?
Not that it matters becasue you cannot do that without some custom programming.
If you run Windchill, then a check-in will generate images for each file in your assembly in ProductView/CreoView, if you have it set to do that.
Ben Loosli
Hi
We are still on Wildfire 4 and Windchill 8.
