Export Drawing Fake Dimension Values via script 1
rickyt
Automotive
Jun 26, 2002
240
Looking to modify code shared in a closed thread to include the Export of Fake Dimension Value.
↓Code below is a portion of it in my attempt to obtain the fake dimension value
Sub CATMain()
' *** Checks if the active document is a CATDrawing ***
On Error Resume Next
Set myDrawing = CATIA.ActiveDocument
If (Err.Number <> 0) Then
MsgBox ("A CATDrawing must be active")
Exit Sub
End If
If (InStr(myDrawing.Name, ".CATDrawing")) = 0 Then
MsgBox ("The active window must be a CATDrawing")
Exit Sub
End If
Err.Clear
On Error GoTo 0
' *** Select all Dimensions ***
Set Selection1 = myDrawing.Selection
Selection1.Clear
Selection1.Search "CATDrwSearch.DrwDimension,all"
' *** Get Dimension values
For i = 1 To Selection1.Count
Set Mydimension = Selection1.Item(i).Value
MyDimensionValue = Mydimension.GetValue.Value
MsgBox MyDimensionValue, , "Real Value"
' *** above here works
' *** Get Fake Dimension Value
' *** Below here fails on obtaining value of fake dimension
'MyFakeDimensionValue = Mydimension.GetFakeDimValue
MyFakeDimensionValue = Mydimension.GetFakeDimValue.Value
MsgBox MyFakeDimensionValue, , "Fake Value"
Next
End Sub
V5 Automation file
GetFakeDim is a Method of DrawingDimValue so you should get this first then call the method on it
dim myDrDimValue as DrawingDimValue
set myDrDimension = Selection1.Item(i).Value ' return the drawing dimension object
set myDrDimValue = myDrDimension.GetValue ' return the drawing dim value object
finally as the fake dimension could be either on the main (1) or dual(2) value we have
FakeDimValue = myDrDimValue .GetFakeDimValue(1)
Eric N.
Eric,
That worked perfect, Thanks!!!
