eit09
- Jul 8, 2009
- 183
I am trying to set up a spreadsheet to automatically do interpolation from a table. I think I need to somehow use roundup with mround to get the correct results. If you take a look at the attached excel spread sheet you can get a better understanding to what I am doing as it is hard to explain! Ok here we go. Cells A15 & A17 are the equations I need to fix. If you look at row 6 the increments are in .05 increments so cells A15 & A17 need to end up with the .05 increments. A15 needs to round down to the .05 increment value and A17 needs to round up to the .05 increment. Does anyone have ideas?
