Redtelis
- Jan 18, 2019
- 47
Hi guys,
Within my ETABS model, I got the ground floor & 1st floor and a mezzanine floor between them. As you can imagine the columns are modelled at each level but the thing is that I want to model the columns which are not within the mezzanine, therefore these columns will be long column with double height as they are formed between the ground & first floor as they are not passing from the mezzanine level.
The thing is that ETABS likes to break the columns at each level and I cannot find a way to model these columns as one single long column. Moreover, this will be wrong during the design check as the height of these columns is double than the others.
Is there any way to stop ETABS break these columns between the levels?
