Engine designs that have problems 22
enginesrus
1,016
Since the one thread I started, is headed way off topic, reason for this.
Engine designs that have problems or have had them.
I'll start with the 3 valve Triton.
This guy explains. Has data from others that deal with the same problems.
Perhaps a review of your maintenance practices should be performed if spinning rod bearings is a common occurrence.
Or employees that didn't care. Some where unavoidable failures, like oil pump drive's, steep ground played a role.
Engine manufacturers offer high incline oil pans for their engines. These often have scavenging pumps in the pan similar to circle track race cars. Is it their fault you didn't specify this when you ordered the engine?
Very familiar with scavenge pumps for high incline. And some engines had that. I wasn't in purchasing.
Are any of them flying anymore? No? Must be planned obsolescence, therefore problem engine. 😉
Here are pictures that I've taken of Curtiss OX-5 engines. The first was taken at the Smithsonian Institute's Air & Space Museum's Steven F. Udvar-Hazy Center, located next to Dulles International Airport in Virginia:
November 2006 (Sony DSC-H2)
The photo of the second engine, it was taken at the National Museum of the United States Air Force in Dayton, Ohio:
November 2015 (Sony NEX-3N)
John R. Baker, P.E. (ret)
Irvine, CA
Siemens PLM:
UG/NX Museum:
I seem to recall reading about a 2 digit overhaul period for the OX-5.
Trying to find it I did find this about OX-5, which does seem worse that modern day quality control issues
Finally, there is the whole question of quality control. Sir Roy Fedden’s remarks on a batch of 250 engines overhauled (or remade) by Brazil Straker, originally in the 1966 centenary journal of the Royal Aeronautical Society, have been widely
quoted:
“— some with broken drills still in the oil holes of the crankshafts –“
“— others with an unbelievable amount of rubbish in the crankcases — including a dollar bill –“
He may have had a point. Early in 2004 the writer warned one UK enthusiast to look out for bad workmanship and build quality on his newly acquired OX-5. He rang, “You were right. Either crap workmanship or sabotage.” “Oh Dear” (or words to that effect) “What’s wrong?”
“There’s a main bearing cap and stud floating around in the crankcase. But it doesn’t matter, it’s a spare. All the caps and so on are where they’re meant to be.
from this document
Thanks...
