phamENG
- Feb 6, 2015
- 7,646
Anybody using this software pairing?
I know several advanced software packages have attempted to use links to tie analytical and documentation model data together, but I've always heard lots of complaints. If they hype is correct, Enercalc has solved it by keeping all model data in Revit, and just pulling out what you need to design individual components (no changing geometry in Enercalc). The only info that gets modified is the beam size if the design plugin calls for it. Sounds pretty slick. If this actually works, it seems like it could fit nicely in my work flow. BUT...I'm a Revit LT user, so it means upgrading to full Revit AND buying Enercalc and Enercalc for Revit. That's about a$3,300$5,164/year investment (assuming I can't get AutoDesk to give me a discount).
Curious if anyone else has tried it and what your impressions and thoughts are.
