Sparweb
Aerospace
- May 21, 2003
- 5,172
What exactly comes out of a lithium battery when it is being overcharged or overheated? Has anyone measured the composition, exactly?
I am in the process of certifying the installation of Lithium batteries in an aircraft. There are some details of this process that I cannot and should not share with the forum, but I have questions about them that neither the battery manufacturer nor the FAA can answer. Hopefully we can get through our Q&A without needing me to describe the entire history of lithium battery installations in the aviation industry for the past 25 years. I hope it's enough that everyone knows they're great, until they aren't, and then they're a problem.
I have been working closely with the battery manufacturer on this project but they can only answer questions to which they know the answers. The manufacturer has done failure tests according to the design standards they must meet. However those design standards don't require measuring the waste products that escape during one of these failures. They didn't need to mount a gas analysis system to the vents of one of their batteries, drive it to failure, and measure what comes out. This means a vital piece of information for me, the installer, is not collected during the melt-down tests.
From a regulatory standpoint, as the installer I am responsible for protecting the aircraft from any products that are emitted from the battery when it fails. I don't get to decide that it won't fail, or how likely it is to fail. Those aren't options permitted by the regulations. Instead I have to make provisions to protect the aircraft from any products from the battery, be they hot or cold, corrosive or neutral, flammable or inert. Having no definition of the waste emitted through the vent I have no choice but to vent it overboard and keep it from running back to harm something else downstream. Remember this is on an aircraft, and if it's liquid it will flow from the battery drain and probably stick to the skin for a long way back. And if it's a flammable gas then it can't come close to anything with a spark (like motors with brushes).
This puts a lot of constraints on the places these batteries can be installed and the protections that go with the battery installation. But I feel like I'm working in the dark, protecting the aircraft (and sometimes its occupants) from harms that may not be realistic. Or worse, due to my ignorance, not doing enough!
Has research been done that tests the failure conditions and reports specific constituents of the effluent?
