tobee
- Apr 1, 2003
- 6
Can any mechanical engineer tell me what would be the effect (if any) of low starting voltage of an electric fire pump on the required water pressure? As you may know, the motor torque will drop in a squared amount as the voltage drops. Do you compensate for the drop in the initial water pressure drop? Any input in this matter is appreciated.
