pt321
- Nov 26, 2009
- 2
When a accessory like a dc/dc converter or inverter with 30A output is used that has a current draw (for milli/microseconds) that is higher than the alternator output rating , what is likely to be the effect?
A good diagram to keep us all on the same line of thought is
pp7 fig. 5-07 of
What response time does the alternator's voltage regulator typically have? I've gone to alternator OEM websites, their .pdf datasheets are sales oriented, no internal technical specs are included.
If the typical small alternator w 60A rating has 120A or even 300A drawn for 1 ms, it appears to me that until the alternator's voltage regulator reacts, current could be drawn directly from the battery, which has an internal impedance, so the batteries Vout would drop.
Then, when the high current draw pulse ended, the alternator's rotor field would be set to deliver higher current, which would then be dumped on the bus, similar to load dump.
Having a load dump like event happen thousands of times per second does not sound like a good way to get normal longevity of the charging system.
Any of my estimations sound accurate?
Thanks for your input,
Paul
pp7 fig. 5-07 of
Paul
