caseynick
- Sep 22, 2005
- 36
Does ASME Y14.1M reference ASME Y14.5 ?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
ASME Y14.1M-2005 said:1.4 Applicable Documents
The following documents form a part of this Standard to the extent specified herein. Unless otherwise indicated, the latest edition shall apply.
ASME Y14.1, Decimal Inch Drawing Sheet Size and Format
ASME Y14.2M, Line Conventions and Lettering
ASME Y14.3M, Multiview and Sectional View Drawings
ASME Y14.5M, Dimensioning and Tolerancing
ASME Y14.1M-2005 said:8.2 Dimensioning and Tolerancing Block
Information relative to dimensioning and tolerancing, such as angular and dimensional tolerances, are given in this block. See Fig 13. Reference to ASME Y14.5M may be included in this block. When used, the block shall be in the title block area.
Fig 13 said:UNLESS OTHERWISE SPECIFIED
DIM ARE IN MILLIMETERS
TOL ON ANGLES ±.XX°
0 PLACE ±X 1 PLACE ±.X
INTERPRET DIM AND TOL
PER ASME Y14.5M-1994
ASME Y14.5-2009 said:1.4 FUNDAMENTAL RULES
Dimensioning and tolerancing shall clearly define engineering intent and shall conform to the following.
(a) Each dimension shall have a tolerance, except for those dimensions specifically identified as reference, maximum, minimum, or stock (commercial stock size). The tolerance may be applied directly to the dimension (or indirectly in the case of basic dimensions), indicated by a general note, or located in a supplementary block of the drawing format. See ASME Y14.1 and ASME Y14.1M.
