Early alternative to ISFORMULA() function 1
Denial
924
I am looking for a way to detect whether an Excel cell contains a numerical value or a formula that returns a numerical value.[ ] In later versions of Excel the ISFORMULA() function would do exactly what I need, but this function is not offered in the version I am using (2010).[ ] I would prefer a solution that does not involve VBA, but will use VBA if necessary.
Engineering mathematician / analyst.[ ] See my profile for more details.
Try this:
Code:
Public Function IsNumFormula(target As Range) As Variant
    If target.Count = 1 Then
        IsNumFormula = IsNumeric(Evaluate(target.Value))
    Else
        'IsNumFormula = "Error:  Argument must be a single cell."  Uncoment this line to return a message
        IsNumFormula = CVErr(xlErrValue) 'comment this line if you prefer a message
    End If
End Function
Thanks, MJ.
Your suggestion points out to me that my request was subtly ambiguous.
Primarily I am seeking a Boolean UDF that will return TRUE if the single cell passed into it is a formula, and will return FALSE if it is anything else.
Thus[ ] =sin(pi())[ ] or[ ] =2+1[ ] or[ ] =RAND()[ ] should return TRUE,
whereas[ ] 3[ ] or[ ] -1.234[ ] or[ ] abcde[ ] should return FALSE.
If it makes things any easier, it would suffice if the test applied was that the first character in the cell should be "=", but I suspect that would be impossible to detect in VBA.
That's actually a little easier.
Code:
Public Function CellIsFormula(target As Range) As Variant
        CellIsFormula = Left(target.Formula, 1) = "="
    Else
        CellIsFormula = CVErr(xlErrValue)
    End If
End Function
You can use either formula in the sheet, to return a Boolean, or you can use them with conditional formatting.
Formulas can start with =, + or - for backwards compatibility with Lotus or Borland or one of the old spreadsheets, so this will be more robust.
Code:
        Select Case Left(target.Formula, 1)
            Case "=", "+", "-"
                CellIsFormula = True
            Case Else
                CellIsFormula = False
            End Select
        Else
    End If
End Function
Thanks again.[ ] First works perfectly for my needs.[ ] Second (obviously) will get negative numbers wrong, so even though my specific application should not encounter negative numbers I will play it safe.
Good catch on the negative numbers.
This should fix that problem.
Code:
            Case "=", "+"
            Case "-"
                CellIsFormula = Evaluate(target.Value) = target.Formula
            Case Else
            End Select
        Else
    End If
End Function
I was looking at a non-vba formula using FORMULATEXT, but since that was introduced in 2013, the same as ISFORMULA, it's not actually much use.
Doug Jenkins
Interactive Design Services
Point taken, IR.[ ] Thanks.
Luckily in my present context this will not arise.[ ] I am developing a spreadsheet for a sports club to use when it is organising tournaments.[ ] The workbook has two parallel columns of text data (people's names).[ ] The first column has the participants' names in alphabetical order, and the second one dis-arranges the names into a randomised order based in a column of random numbers [generated using =RAND()].[ ] So, initially, every time any change is made to the worksheet the randomised order re-randomises.[ ] There comes a time when this re-randomising has to stop, so that rosters etc can be printed and posted.[ ] I told the club that the simplest way to stop the re-randomising is to use the copy and paste-copy operations to convert all RAND() functions to their current values.[ ] I intend to use this new UDF in an updated version of the spreadsheet to ensure that the conversion is properly and fully done.
Turning off automatic calculations should achieve that goal. A macro that runs onsave or onopen to force the calculation to manual and looks to see if a cell has the word "final" in it would do the job automatically, maybe set the contents of another cell to "manual" or "recalc" to signal the calculation status.
Ok, I think this is robust. Let me know if you can break it.
Code:
Public Function CellIsFormula4(target As Range) As Variant
On Error GoTo ErrorHandler
        CellIsFormula4 = Len(target.Formula) > Len(target.Value) Or IsError(target)
    Else
        CellIsFormula4 = CVErr(xlErrValue)
    End If
    Exit Function
ErrorHandler:
    CellIsFormula4 = True
End Function
[pre]CASE Target Vale Formula IsForumla4
string abc abc abc FALSE
number 123 123 123 FALSE
formula 3 3 =1+2 TRUE
formula+ -3 -3 =1-4 TRUE
formula- 4 4 =-1+5 TRUE
formula returning error #N/A #N/A =VLOOKUP("A",N13:O17,1) TRUE
formula returning error #DIV/0! #DIV/0! =1/0 TRUE
blank 0 FALSE
- - - - FALSE
1234567 12345 12345 12345 FALSE
[/pre]
Many (MANY) years ago, I attempted to set up a systematic test to establish exactly how Excel's various ISxxx() functions responded to the various types of arguments that might be thrown at them.[ ] I have added MJ's CellIsFormula4() function to that tabulation.[ ] It passes all the tests I could think of at the time I made the spreadsheet.[ ] See attached.
 https://files.engineering.com/getfile.aspx?folder=f84b1364-3511-494d-a921-2b1da5630b2a&file=Testing_IS_functions.xls
I managed briefly to get my fingertips onto a computer with Excel-2013 on it, and loaded my Testing_Is_Functions.xls spreadsheet onto it.[ ] I then added a column for the ISFORMULA() function.[ ] Comparing the results from ISFORMULA() and CellIsFormula4() the following cell contents gave different results.
.[ ] (Just a single, lonely decimal point)
'55
'1.98D09[ ] (but not '1.98E09)
Fred
=T(5)
=NA()
=Fred(A4)[ ] (ie a non-existent function)
=SQRT(-1)
=(A4=A9)[ ] (where A4 did not equal A9)
[ ] [ ] [ ] [ ] [ ] [ ] [ ] [ ](I didn't think to test the case where A4 did equal A9)
In all these cases I think ISFORMULA got it wrong and CellIsFormula4 got it right (although a few are arguable).
In all these cases I think ISFORMULA got it wrong and CellIsFormula4 got it right (although a few are arguable). said:
hmmm... Excel 2021 had the same results as CellIsFormula4 for all those cases.
TTFN (ta ta for now)
In order to get results for the ISFORMULA function, I sent my test spreadsheet to a friend with a more recent Excel version and asked him to do the testing.[ ] The results I reported two posts up come from what he reported back to me.[ ] I have since established that he uses Excel[ ]365.
I had a quick look at the download spreadsheet and found that for:
=PI()+1
or just =PI()
The Excel ISFormula function says it is a formula, but CellIsFormula4 says it isn't.
It seems to me that any short formula returning a floating point value will be found to be not a formula by CellIsFormula4
Doug Jenkins
Agree. Note that "=3.141592654" returns TRUE for both IsFormula and CellsFormula4, but it's not strictly a formula, since no calculation is involved.
