Draw Rectangle
bart1
10
In Autocad 2002 I cannot draw a rectangle when I pick Draw and then Rectangle. It does not ask me for first coner.
Any help?
Jim B
Did you type in the command?
I believe it's "rectang".
If that doesn't work. Then it sounds like the lisp might be corrupt or missing. Copy it from someone else's machine and overwrite it on your machine OR re-install AutoCAD 2002.
Hope that helps
Rich@LG (Architect)
It works in 2002. Maybe you need reinstallation. Try with typing into command line as follows:
Command: rec and Enter.
If you dont get wright prompt, you need to install AC again!
Good luck!
