Dragging a drafting symbol
Befuddled
Aerospace
Jan 9, 2008
78
Hi all,
If you a have a drafting symbol on a drawing sheet (not attached to anything), is there a trick (keyboard button etc) which can be used to force the symbol or object to only drag in the X or Y axis?
Thanks in advance
Befuddled
If you use the move object command (dynamic option), you can drag on the arrows to move it in the desired direction. I don't know of any tricks to lock in a direction when just dragging a symbol with the mouse, but a method to do that would be useful. Maybe file an enhancement request (ER)?
www.nxjournaling.com
Cheers, didn’t think of that.
I’ll submit a ER, should be an easy one for Siemens to deliver
B.
