KENAT
- Jun 12, 2006
- 18,387
I have a colleague that is designing both the male & female halves of a dovetail joint. The dovetail is used for a detachable optical assembly and variations there on have been used with adequate performance for some time at my employer. However since most of those were introduced the company has become more aware of tolerance/repeatability issues and is now using GD&T (ASME 14.5M-1994).
He has asked me how I would keep the angled edges in the same alignment, ie effectively keep the width of the dovetail the same to a fairly tight tolerance. The term parallel keeps getting used but isn't really correct.
My initial suggestion was just to control the surfaces with surface profile however he doesn't seem convinced by this. He is very concerned about keeping them aligned but doesn't seem as concerned by other factors. My other suggestion was to call out a fairly tight perpendicular tolerance to the end face but while this would help keep the edges aligned it isn't really necessary for the dovetail to be highly perpendicular to the end face.
Now I'm not convinced he's correct as once installed a screw pushes in from one side pushing the dovetail to the other, so I don't see why they need to be tightly controlled but he's convinced.
He wants to call out the machining process, saying they are to be machined in a single step but obviously this doesn't fit well with standard drawing conventions, I'd rather detail the end requirement not how to achieve it.
Any ideas appreciated, simplified sketch attatched to give some idea of the female.
KENAT, probably the least qualified checker you'll ever meet...
