itsmoked
- Feb 18, 2005
- 19,114
I am trying to deliver a pressure profiled dose of water.
About 3 oz or 90ml per minute.
I have tried a very small expensive gear pump and I'm entirely dissatisfied with the static leakage thru it.
I have about 30 psi of feedwater to the system and I want to be able to provide about 1.5oz over about 1/2 a minute with a pressure of anywhere between zero and 130psi.
With my current pump/system I am faced with 30psi to 130psi and the difference in flow is only about 1:2 over the leak thru verses 130psi.
Any suggestions of systems or techniques I should be looking at? I am not having much luck with search terms either.
I can actually have a recharge period of a few seconds per dose if that broadens the field of choices. Syringe/piston style??
Keith Cress
kcress -
Keith Cress
kcress -
