Document numbering system for projects.
pumas
Chemical
Aug 11, 2004
1
Is there a standard for document numbering?
PFD's / P&ID's / DataSheets / Hookups / Layout Plans / Outline Drawings / etc etc
The document numbering system we currently use is not as "modern" as it should be.
Example:
Doc No.: OUDV-12345-001
OUDV = Document Type
12345 = Sequential Number
001 = Revision Number
The problem is, that this document doesn't has any link to the project. (There is no Project - ID)
I guess that most companies includes a project ID into their document number.
Example:
CA.065871.P1.123
CA = Country code (China)
065871 = Job Number (Project ID)
A = Document Type (P&ID)
1 = Document Classification (Final Documentation for customer)
123 = Sequential Number
This was an idea we had for a new numbering system. It would be very interesting for me to see other examples.
Every company has their own way of part numbering. Whatever works for you. I say keep it as simple as possible. If you follow ANSI/ASME/etc standards, drawings have most of the info on them anyway.
