FreddyMusic
- Dec 10, 2005
- 36
See below specification from a reputable brg manufacturer catalog
Cr (KN) Co (KN) d X D X B (mm)
4P QJ 308 = 86.5 68 40X90X23
DAC 3308 B = 62 45 40X90X36.5
AC 7308 B = 50 32.5 40X90X23
4 points (4 P) has higher load capacity as a double row angular contact (DAC)?
It seems like 4 P is a kind of DAC, but two row race share one row of balls.
Then see this,
4 points (4 P) has higher Load capacity than angular contact (AC) with same OD. ID. Width.?
What about we put the same load (only one direction axial load) on both brgs and do test life?
I assume P = 50 KN, from Life equation L10 = (C/P)^3
We have conclusion, 4P is 5.18 times longer life than AC.
Under same load, with same dimension and material,
Is 4 points so capable on life, with a not super finished outer race?
Did anyone really test 4 points brg life ?
or have some application experience ?
What is 4 points brg ? DJ what do you think ?
Then see this,
