fifi121
Chemical
- Jun 29, 2009
- 8
I have a distillation column and the overhead stream is to be condensed, pumped and some %age of the pumped liquid is to be sent back to the column as Top feed stream. As to converge the column all the feed streams to the column must be already converged, I can not converge the column if I dont specify the pump discharge stream. and by specifying the pump discharge stream, it shows inconsistency message in the stream and can not converge...
so anyone can please guide how to simulate the column overhead that is sent back to the column as reflux stream after condensation???
