Matt17
Chemical
- Oct 9, 2010
- 23
Dear all,
my guess is to displace sea water from a long pipeline (kilometers) with fresh water without any physical separation. To do this I've to size an adequate pumping spread in order to assure a minimum velocity in order to avoid stratification along the pipeline. Any idea to roughly estimate this minimum velocity? ... I know the AGA indicates a minimum velocity as a function of density difference, but AGA speaks about gases ... Suggestions?
Tahnk you all
Matt17
Process Engineer
Tahnk you all
Matt17
Process Engineer
