bearisle
- Jun 2, 2004
- 77
I completed a print, printed it and saved it. Everything looked good. When I re-opened it, many dimensions did not show up on the screen. They appear on print preview as well aas actual print. If you click around the general area where these dimensions should be, you will be able to blindly select them and they will appear until un-selected. I made sure layer was on. I found that if I selected it and changed the color from white to green, it then appears. I can change it back to white and evrerything appeaars fixed. Any ideas?
