eejacky
- Oct 26, 2002
- 19
I encountered the following problem during our work. I hope the experts can help to solve this problem.
I work in 132kV transmission cables. At one time, I tried to use the digital multimeter to identify the correct cable from one end to the remote end. The cable is about 3km long. In one end, I used the digital mulitimeter such that the positive wire was connected to the core of the cable and the negative wire was connected to the earth. In the remote end, my colleague used a copper wire to connect the core of the cable to earth. The test is very simple. If the circuit is closed, the buzzer of the multimeter will alert whereas no buzzer is alerted in case of open circuit. Howver, during the test, I found that the buzzer alerted every time when I shorted the positive wire of the multimeter on the core of the cable and the negative wire to the earth, but without shorting the remote end to earth. After that, I used Meggar meter to test again. I switched to 500V and the testing procedure is the same as mentioned above. In this time, the test result is normal. My question is why multimeter showed closed circuit any time in this case. In fact, it is impossible for the core of the cable short circuit to the earth physically. Is this related to the limited function of the digital multimeter? But I want to highlight that successful story was achieved in past job reference (I mean use multimeter to identify the transmission cable to test a long cable (>3km))
I really hope the experts can explain the reasons behind this.
