greenimi
- Nov 30, 2011
- 2,391
I have a quick question for the GD&T experts. Should be an easy one for your level of expertise.
See drawing attached:
- Picture A is the original design intent
- Picture B is the proposed one (proposed one is to make this part inspected by a functional gauge, a simple go functional gauge, NOT an assembly with multiple pins, etc)
Question: By changing the positional callout from Ø.005 to Ø .002 are we keeping the design intent? decrease with Ø.003 (Ø.003 is from the additional datum shift allowed by adding M at the Datum Reference Frame: .378-.375 =.003).
What is your opinion about this approach? Will hold some water?
Note: Engineering is okay to make the updated print more tight/stringent requirements, but NOT to relax any of these requirements.
I kind of know that this approach could be valid (if it's valid) only in this special case (only one feature to be controlled relative to a datum, and NOT valid with multiple features/ patterns).
Again, is this concept valid from your point of view? Any thoughts?
THANK YOU FOR YOUR HELP!!
