Keith1976
- Feb 9, 2009
- 48
Hi All;
I am using FC202-200kW to run a centrifuge pump (distribution pump). Since I only make use of the soft start and soft stop, I run the inverter in Hand mode and press the '+' button to reach 50Hz output.
But the display show that the maximum is 47Hz and status is RAMPING, not RUNNING.
I check the current and it is still below the current limit.
Does anyone have an advice why this is happening?
Thanks in advance,
Keith
Thanks in advance,
Keith
