Custom Report Templates
chris456s
50
I have a some results. I want to change a column width in the default template. So I hit edit report template. In the editor I change the width on the correct field. The preview looks good so I save the template with a new name and close. But when I try to generate the same report again, the result values do not populate. Just a blank page. Wow this software is finicky. What am I doing wrong? So weird, changed only the width. Values where in preview....but does not regen....
Issues like this should really be directed to Hexagon Tech Support, using the Smart Support portal.
Richard Ay
Hexagon PPM (CAS)
