Custom Excel Function 1
enirwin
46
I'm creating a custom function in Excel using VBA. Does anyone know how to add variable descriptions that will display in the insert function dialog box?
Thanks.
This is not a trivial task. Laurent Longre figured it out some time ago, and published FunCustomize.dll. I don't know where I downloaded this from, but a little googling will probably help you.
Cheers,
Joerd
I found the application, but the documentation indicates that it is only set up for four functions. Is this correct? If so, is there a way to make it accept more?
Thanks.
Disregard my previous post. I misunderstood what I was reading in the documentation. I tried it and it works perfectly and does exactly what I need.
Thanks Joerd.
