RalphChristie
- Jun 25, 2002
- 648
Hi
After a discussion I've realized I had a lack of knowledge on CTs - any specifically on specifying the magnetizing current of a Class PTX (X) CT, thus an CT been used in the IEC-world.
In a class X CT the performance is defined in terms of a knee-point voltage and the magnetizing current at the knee point voltage or 1/2 or 1/4 the knee-point voltage. Normally the client should specify the knee-point volatage and the magnetizing current. To obtain the required knee-point voltage is not an issue, but how would you define the magnetizing current? Thus, from the clients perspective,(or out of the field perspective) how should you choose the value of the magnetizing current? Any rule of thumb or formula to be used? I do understand Eskom (South African Electrical Utility) specify it as 4mA/turn - but do not know where the value is been obtained from. Any ideas from the CT-manufacturers? Scottf?
Rgards
Ralph
[red]Failure seldom stops us, it is the fear for failure that stops us - Jack Lemmon[/red]
Make the best use of Eng-Tips.com
Read the Site Policies at FAQ731-376
Rgards
Ralph
