dfly9891
- Dec 22, 2009
- 29
Hi All,
What do you know of Cryogenic Processing? I came across this link...
I called them up and asked about the process. They soak the parts at LN2 temps for a number of hours, then temper the parts in the oven and repeat a few times.
I have some 304 SS and TI Grade 5 parts that will be soaked in 25K temperatures with some cycling. Furthermore, I have a 17-4 shaft that will rotate at 200+ [krpm]. So, I'm wondering if I should give this process a try in order to minimize warpage of the 304 bearing housing and the 17-4 shaft. Shaft diameter is 3/8", length 2". Bearing housing ID is .430 and OD is about 3.5"
If I go with it, I would0 turn the parts down to rough dimensions, cryo-process them, then finish machine. Thoughts?
