Creating a Mirrored Surface 2
GBor
1,497
Glancing through the FAQ's and searching the forum, I didn't see this one, but I'm sure it exists somewhere: I'm trying to create a mirror. I know to select the surface, go to the face properties and click on the advanced button, but the settings for ambient, diffuse, specularity, shininess, transparency, and emission are eluding me. Anyone?
Thanks in Advance!
You must be using PhotoWorks right. The best mirror surface that I've come up with is to use "mercury" as a material(its under metals). Then your options for ambient, difuse etc... will be selectable. Before you make any modifications to those settings, select mirror from the material type drop down. This should get you started.
"Perfection - a result of many mistakes."
BJH
Look in Help under:
"Appearance and Material Properties".
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Check thread559-87160
[cheers]
Helpful SW websites every user should be aware of faq559-520
How to get answers to your SW questions faq559-1091
