Randy1111
Mining
- Jun 2, 2006
- 42
I used search, and found some closed threads only so i had to make a new one.
I have created an assembly, with all parts, and drawings as a template. The whole system is run via design tables with vba programming, works real slick.
All my guys need to do is copy the template, run the macro in the design table, and get a new custom designed part with drawings almost complete.
Trying to now impliment it all in pdmworks.
I can find no way for them to copy the project or assembly/children.
They cant all have admin rights so copy project will not work.
Pack and go does not seem to work for items in the vault.
So is the only way for me to keep the template outside of the vault, and then have them use pack&go, copy everything to a new name directory, edit to new specs, then check into vault?
And if thats the only way, what happens to common parts, like bearings and such that are stored in the vault but used in the template?
Randy
Randy
