converting visio fills into autocad files
DougZ
Mining
Mar 23, 2000
1
I am using Visio ver 5.0a Technical.<br>
The project requires that drawings be done in Visio, saved as Autocad dwg files, and later converted using Whip-N-Post to dwf files for web pages. (the dwf feature of Visio does not work)<br>
<br>
The problem is that when I use Visio fills the fill portion does not translate into the Autocad dwg file when I use
Sorry for the answer, but there is no way to do this. If you wnat use *.wmf files. For sure, any save of Visio file in CAD format will cause loss of formats. What
I do - I save the *.vsd file in *.pdf format, than using Adobe Acrobat I save it like *.htm or *.xml.
