op9
Industrial
- Aug 18, 1999
- 111
I am involved with a particular asphalt plant burner (diesel fueled) installation which has a problem with the emissions of hydrocarbon smoke at low fire which translates into "smell" for the local residents. My analyser only measures O2, CO, NOx and not hydrocarbons. I am able to visually reduce the smoke with no material in the drum. In production it is a bit more difficult as there is the accompanying steam being emitted. On this particular burner which is unfortunately quite oversized for the job the CO (partly burnt) can be controlled and managed but we need to keep a check on the unburnts which I think is vaporised diesel.
A testing company came (at great expense) and did VOC readings as well as CO and NO2 in mg/nm^3. I can easily convert the NO2 and CO to ppm knowing molar volumes and they are about the same as mine. How do you convert the VOC to a similar volume relationship?
They came up with a figure for TVOC of 22mg/nm^3 at start up which reduces to 8.8 during normal running. What I have available to measure the emissions of "hydrocarbons" is a Drager test pump which uses chemical filled test tubes which "stain" to show a reading. They are available in only certain ranges. The two which measure Petroleum Hydrocarbons available are 100-2500ppm and 10-300ppm. So I need to know how to relate ppm to mg/ nm^3. Both of these also show the CO reading as a hydrocarbon. However I can subtract this (known value) from the total reading to achieve a representative value for comparison.
In this way I can get a feel for whether my burner adjustments have achieved a reduction in the TVOC's before the proper measurements are done.
Would appreciate any help.
Rod. Rod Nissen.
Combustion & Engineering Diagnostics
nissenr@iprimus.com.au
Rod. Rod Nissen.
