controlnovice
- Jul 28, 2004
- 976
Looking over an Electrical Design specification for a proposed plant in Germany (owner and Engineering oversight in the USA), the MCC low voltage level is 400V, 50Hz, 3 phase.
Smaller loads/motors will be 230V.
The specification indicates that the control voltage (for contactors, etc.) will be 110VAC.
I've seen 220VAC used directly from the 380V bus for motor contactors, but not stepped down to 110VAC.
Is 110VAC common in Europe for control voltage?
______________________________________________________________________________
This is normally the space where people post something insightful.
