CONICAL SPRING 2
pardal
Automotive
Oct 17, 2001
444
Please give me the facts and formula that handle the conical round wire spring .
Pardal
ency
I am residing out of the USA therefore I am not familiar with spring design experts in the US. I have more than 25 years of experience in mechanical springs design for commercial and aerospace use. I am also the developer of an expert system for mechanical spring design as you can see at .
Currently I am surving as a freelancer consultant where within other areas of my expertise I am consulting and designing mechanical springs for tough cases (such as your case).
Meaningly, where space is very limited and where the commomn designer fails to get satisfactory results by using off the shelf springs, off the shelf software for mechanical springs design, standard handbook for mechanical springs design or the common literature for mechanical springs design.
hello everybody,
I am looking for a vendor that specializes in concical springs...the dimensional sizes are .750 large od. .44 small od, wire dia. .030-.035 and height is .750.
material SS
It will be better if you can start a new post.
Can you give more information Such as:
1. Forces and deflections requirements at two points
2. Are you interested in a non-linear force deflection behavior or a linear behavior
3. Is it a static loaded spring or cyclic?
4. If it is cyclic what are the load and deflection at both points?
5. Environmental conditions
