Compress & External Pressure Charts/Tables 1
BigTank
368
I am having trouble correlating a value for 'A' given by Compress and one looked up (and even interpolated) manually when calculating a shell and ellipsoidal head for external pressure.
I was wondering if anyone knows how Compress finds this value? I would assume that the method used for finding a value from Figure or Table G would be the same method for finding value B from the appropriate chart.
Fitter, happier, more productive
BigTank,
I believe Compress uses double logarithmic interpolation of Table G.
I have developed a spreadsheet for doing logarithmic interpolation. Tell me the values of L/Do and Do/t, and I will give you the value for 'A'. See if it matches the one calculated by Compress.
Thanks, doct!
L/Do = 1.7037
Do/t = 247.8448
That is very close to what Compress gives in the calcs.
Interesting...UG-28(c)(1) Step 3 states: '...interpolation may be made for intermediate values of Do/t...'
I used linear interpolation using the tables...probably not the best method. Looks like I'll be developing your spreadsheet for myself, doc.
Thanks again, doc!
