DougP100
Geotechnical
- Mar 13, 2003
- 6
Hi:
I am in the process of analyzing an existing floor to determine the maximum load it can take. It was constructed in the 1930's, and is a composite floor featuring a 4" lightly-reinforced slab that sits on a W6x12 beam. The beam is entirely encased in concrete, and the slab and beam appear to have been cast at the same time.
I am analyzing this as a T-Beam with the slab (or actually the upper portion of the slab) as the compression element and the W6x12 as the tension element. My question regards the modular ratio.
I have computed the modular ratio, n, as 8.6, using E = 29,000,000 for the steel and ACI 8.5.1 for the concrete.
I have approached the analysis from 2 points of view using the Theory of Transformed Section - Converting everything to steel, and converting everything to concrete.
I have calculated the location of the centroid from both perspectives. From All-steel P.O.V. (Point of View) I divided n into the concrete values and solved by completing the square. From All-Concrete P.O.V., I multiplied the steel values by n and solved by completing the square. Both ways yielded the same centroid location. My problem arises when I compute the Moment of Inertia, I, of the transformed section.
When I approach things from the all-steel perspective, I have divided n into the I of the concrete before adding A x d squared. When using allowable f values for steel and concrete, and using the standard f = Mc/I equation, I get one set of allowable moment values.
When I approach things from the concrete perspective, by multiplying the steel areas by n, and leaving the I values alone, and using f=Mc/I for the same allowable f values, I get significantly lower moment values. I had believed that they should be the same.
I suspect that this may be a Math error on my part and I deparately need to brush up on my algebra. Or perhaps I goofed up and one way is better than the other. Maybe I am 100% wrong in my analysis methods. Any way, could someone shed some light on where I am screwing up? I am a geotechnical engineer, and I don't do this too often....only when I have to.
Thanks!!
Thanks!!
