designmgr
Automotive
- Sep 22, 2005
- 3
I am trying to dimension a print for an assembly made of multiple formed plastic lines, joined together by "T" and "Y" connectors, and terminating in multiple quick-connectors.
In use, this assembly is installed by first connecting these QC's to their mating parts, then the plastic lines are snapped into retaining clips at various locations along their length to keep them from moving around. This assembly is typically 1-2 feet long with multiple bends.
Typically for a single quick -connector, the diameter of the mating feature (cylindrical in shape) would be a primary datum, and the feature that limits the insertion of this mating feature would be secondary. This particular assembly has 3 QC's, so I now have 6 datums.
When this part is gaged, I want it to be fixtured as it is used. My main concern is that when installed per intent, the profile of the tube falls within a certain tolerance from the basic dimensions. This means that in addition to the 3 QC's, I also want it snapped into gage features representing the clips that hold the lines in place. There are two of these clips, so here are 2 more datums.
A voice in my head tells me no more than 3 datum references, or on can combine datum features within a single box in the frame by joining them with hyphens. Not sure how to proceed:
[profile of surface|x.x|A|B|C|D|E|F|G|H] with some note detailing Gaging procedure?
|A-B-C|D-E-F|G-H] or some other combination to honor the 3-datum "rule"?
Thanks!
Thanks!
