SteveBzzz
- Aug 2, 2002
- 11
Greetings,
I am puzzled by the seemingly different behavior that Cola exhibits under different bottle sizes. For example, I opened a new 2 liter bottle of Coke. I then distributed it between 2 smaller containers and the remaining in the Original Bottle.
The Coke distribution is as follows:
Bottle 1: Filled to Capacity , 0.5L (Approx).
Bottle 2: Filled to Capacity , 0.5L (Approx).
Bottle 3: (Original) Contains , 1.0L (The Remaining).
After 2 hours, all of the bottles are opened, and their contents are tasted. The results that I experienced are as follows:
Both bottles 1 and 2 were "flat" (Less carbonation), and had a displeasing taste. The Coke in bottle 1 maintained the same taste and carbonation level that it originally had (Approx.)
My question is this: Why does the coke in the smaller bottles lose carbonation, while the coke in the larger bottle remains unchanged? Here are some of my observations.
After a small amount of time (1 hour), the smaller bottles are highly pressurized and the containers are generally hard to squeeze. The larger bottle is easy to squeeze. Why does it seem like the smaller bottle is under more pressure than the larger bottle, but yet the soda from the larger bottle is more carbonated and tastier? All containers were filled with extreme caution so as not to produce surface "fizz." The containers were both cold from refrigeration.
Also, I recently purchased one of those pumps that replaces the bottle cap of a soda container. When pumped it re-pressurizes the container, supposedly maintaining freshness. The instructions say do not pump to such a degree that you cannot squeeze the bottle, as this device is more effective at a lower pressure. Why not higher?
What am I missing?
Any help would be greatly appreciated.
What am I missing?
