Coding Journal UF type commands 1
Twullf
196
I have been attempting to use the UF_DISP_set_display command to turn off the display while journals run, but I cannot get it to work.
I have tried calling
SetDisplay(UF_DISP_SUPPRESS_DISPLAY)
I get:
Name 'UF_DISP_SUPPRESS_DISPLAY' is not declared
I have tried
Dim display_code As Integer
display_code=UF_DISP_SUPPRESS_DISPLAY
SetDisplay(display_code)
I get:
Reference to a non-shared member requires an object reference.
I have tried
I get:
Name 'display_code' is not declared.
I know I am missing something incredibly basic but I'm not sure what it is or where I should look. I have been all over the NXOpen reference documentation trying to figure this out but I am missing something fundamental.
Thanks in advance for your help.
UF_DISP_SUPPRESS_DISPLAY is a constant declared in the API. I assume you have added Imports NXOpen.UF at the beginning of your code. If so, you can reference the constant like this:
Code:
UFConstants.UF_DISP_SUPPRESS_DISPLAY
www.nxjournaling.com
I have referenced the following at the beginning of the code:
Imports NXOpen.UF
Imports NXOpen.UF.UFDisp
with the following code:
display_code = UFConstants.UF_DISP_SUPPRESS_DISPLAY
SetDisplay( display_code )
I get the error:
I got the same error when trying to use the UFConstants line directly instead of using display code.
I have checked to make sure our license allows us access to gateway.
Thanks for the help Cowski.
Do you have a reference to the UFSession?
Code:
Dim ufs As UFSession = UFSession.GetUFSession
ufs.Disp.SetDisplay(UFConstants.UF_DISP_SUPPRESS_DISPLAY)
'do stuff
'unsuppress display
ufs.Disp.SetDisplay(UFConstants.UF_DISP_UNSUPPRESS_DISPLAY)
The program works.
Awesome Cowski as always your advice is excelent.
