climb time
Rollerblades
34
Could somebody explain me how to calculate the climb time from the maximum climb rate, because I can't correct my report. Thank you.
deltaH = ROC * t
ROC is a function of altitude.
STF
You may want to express Rate of Climb (ROC) as a function of altitude, and then integrate the expression over the altitude region which you are interested in.
jetmaker
Thank you very much, but I found it. The source of error may come from SFC with the thrust varying with the mach number: how do I take into account this? Thank you.
Now you need engine data. A T-v curve with lines for various altitudes is (I think) a standard format.
STF
