DVWE
Petroleum
- Apr 5, 2007
- 2,317
Most filler metal manufacturers class ER70S-6 as F-No. 6, A-No. 1. However, both Mn and Si as listed in SFA-5.18 can exceed the limits of QW-442.
So my question is, in order to classify this wire as A-No. 1, do I need a certified MTR from the manufacturer for every lot of wire which we use in production? If this is the case, I am assuming that a weld pad made per the requirements of the SFA must be followed using the same shielding gas?
\Thanks in advance/
\Thanks in advance/
