RJB32482
Chemical
- Jan 19, 2005
- 271
Here are the conditions of the relief scenario I am looking at:
Case: Fire
Set Pressure: 120 psig
Relief Flow: 350 SCFM
Relief Material: Air
Now there is about 8 feet of piping in between the outlet of the relief and its discharge into atmosphere. To find if the flow is choked, how would I calculate the pressure at the outlet of the relief device? Would it just be atmospheric pressure or atmospheric pressure+(pressure drop through piping at relief conditions). Then using inlet pressure and specific heatt ratios, I could find if the outlet of the relief device is choked or not.
Thanks.
Case: Fire
Thanks.
