DavidFinAZ
Chemical
- Nov 20, 2018
- 2
I'm a ChemE who spent an entire career in semiconductors. Now, I'm trying to invent something but don't know much about plastics. My immediate concern is creating a water-tight seal between some plastic parts of a functional prototype.
I have two flat plastic rings of the same size (2"OD x 1.5"ID x 1/8"THK). I want to glue and/or weld a thin plastic film, 2-4 mils thick, between the two rings. The prototype rings will be manufactured via 3-D printing. In production, I expect that the rings will be injection molded.
If I use an adhesive to join the plastic parts, it will be either, Sikaflex 291 (polyurethane) or DowSil HM2500 (silicone hot melt). If I choose to weld, I don't know if the method will be ultrasonic, RF or laser welding.
QUESTIONS
1) If I choose to use either of the above adhesives, can someone recommend a preferred plastic material for the rings and thin film? (Note: There is no constraint on the choice of plastic for any of the parts EXCEPT that all materials MUST be NSF 61 compliant.)
2) Is there a preferred combination of plastic materials & plastic welding method (i.e., a method that will create the most consistent, reliable seal)?
3) There may be some pleating (i.e. accidental folding which would increase the film thickness in some areas) of the plastic film immediately prior to welding. Would all of the above welding methods (ultrasonic, RF or laser) be able to accommodate this variation in the film thickness without any problems?
QUESTIONS
