cftime and ascftime (ANSI C)
muverguz
Computer
Dec 13, 2001
Does anyone know where I can find the code for the cftime and ascftime functions? and possibly the ascii equivalent?
Thanks in advance
M
Hi Laffalot
Thanks for the links but I'm sorry but none of them actually show the code for cftime or ascftime. I am looking to either rewrite them or find an ascii equivalent.
M
Is it you want the code that executes as the functions are executed or examples of the functions themselves.(I thought you wanted the latter)
If its the former then you want the code that the compiler compiles as it interprets the function from the time.h library. Mmm tricky.
shows what functions are inside the time.h library
A book on the code in the libraries including time.h
Failing that, right a quick program, including the time.h library & the command you want. Compile it then decompile it and see how the command looks.
Any help ?, yes no let me know.
