ChipFuller
- Apr 18, 2003
- 47
I have a situation that I’m trouble shooting. We have process where are trying to maintain some small process vessels at 100 degrees F. The process is a closed loop water system running through a shell & tube heat exchanger which is heated by 15 psi steam on modulating valve. The centrifugal pump is 3 HP pump running at 50 psi head differential and 10 gpm.
Here’s the problem. The temperature keeps rising past the 100 degree control point. I think the problem is the pump is adding too much heat to the system. After looking at the pump curves, the pump is operating at close to dead head conditions. Here’s my questions.
What is the formula for calculating the heat transfer rate?
The local pump representative suggested a Gould multistage pump with a ¾ horsepower pump to reduce the heat input. Does this sound like a logical suggestion? How much will this reduce the heat input?
Is there any other suggestions?
